Why do my sweeps change shape in the curves?
I'm making a simple sweep. the section, a square block and a the guide is equally simple. as the sweep passes thru the curves, its width gets smaller. could this be a setting. is my section not staying perpendicular to the guide?
To see what I'm saying, look here: http://p utfile.com /pic.php?p ic=4/11122 411069.jpg &s=x11
I'm using NX 3 & NX 4.0 Same in both.
RE: Why do my sweeps change shape in the curves?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I dont know, I only saw a sweep along guide. if its free form, I dint know where to switch it.
You can't switch it. The features cowski is asking about are 2 separate features...completely different commands. You can tell the difference by looking at the icon in the Model Navigator or by editing the feature and describing what options are available.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
insert-->sweept
it uses multi guide string and section.
you note spine
