SolidWorks API Error
Hi All.
I am doing a system where i want to put a code and a description of a item into the custom properties directly.
I have this source code, but have a error (type mismatch) every time when i want to use. Anybody can help me?
[]'s
Adriano
Dim swApp               As SldWorks.SldWorks
Dim swModel             As SldWorks.ModelDoc2
Dim swSelMgr            As SldWorks.SelectionMgr
Dim swFeat              As SldWorks.Feature
Dim swCustPropMgr       As SldWorks.CustomPropertyManager
Dim nRetVal             As Long
Dim vNameArr            As Variant
Dim vName               As Variant
Dim bRet                As Boolean
Set swApp = GetObject(, "SldWorks.Application")
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swFeat = swSelMgr.GetSelectedObject5(1) -> Error
Set swCustPropMgr = swFeat.CustomPropertyManager
RE: SolidWorks API Error
Withoug running the code myself, I believe that if the selected is not a feature, then you will get this error.  I would suggest testing the selection first then if it is a feature set it equal.  Of course the Feature.CustomPropertyManager call is used with Weldment features.  Is that what you are doing or are you trying to set the document custom properties?
Try "CreateObject" instead of "GetObject".
I agree with "SolidAir" you need to qualify that your selection is a Feature BEFORE assigning it to your "swFeat" variable.  If you don't do this, that's going to cause a type mismatch every time there is a non-feature selection (e.g. a note, dimension, etc.).  I don't have my API manual handy here at home so take a look at the documentation code samples.  There should be an example in there on how to do this.
One additional thing, I'm fairly certain that you probably could achieve the end result you by assigning your selection to the ModelDoc2 variable.  Drilling down to the "leaf" shouldn't be necessary.
Hope this helps out a bit.
Chris Gervais
Application Engineeer
CADD Edge
