Can't Install Solid Edge-Help
I got the Solid Edge V16 CD and I can't install the programm because when I open the setup, it gives an error message saying "Solid Edge V16 Setup has found an existing Solid Edge product. Please use Add/Remove programs applet to uninstall Solid Edge."
The problem is that I don't see solid edge already installed in the add/remove program because I uninstalled it a while ago.
Any tips for fixing this?
I have solid works 2004 and unigraphics already installed on the computer so maybe those are getting in the way?
Also I used to have solid edge installed so maybe I have to remove it from the registry as well?
RE: Can't Install Solid Edge-Help
on the SE CD you will find a utility:
X:\SptTools\SECleanup\SECleanupAll.exe (X - the CD drive)
let it run and and the try to install.
Within the registry you may dekete the following keys (complete)
HKEY_CURRENT_USER\Software\Unigraphics Solutions
HKEY_LOCAL_MACHINE\SOFTWARE\Unigraphics Solutions
HTH
dy
