Flow Meter
Flow Meter
All,
I am looking for the best flow meter to measure 20-80 GPM of flow in a 3" Diameter PVC Pipe. The pipe is moving water with high concentration of steel scale. We have tried a conventional paddlewheel, but the scale is sticking to the padles and stopping the sensor. Any suggestions would be helpful.
Rich......
Rich......
Richard Nornhold, PE
RE: Flow Meter
Good luck,
Latexman
RE: Flow Meter
JMW
www.ViscoAnalyser.com
RE: Flow Meter
Clamp on meters can be a better option so that you will never lose accuracy due to scale deposition on the flowmeter walls(Hint:constant cross sectional area).
RE: Flow Meter
