Torque for M24 SS 316 HCS w/ anti-seize?
Need torque value (ft-lbs) for type 316 stainless M24 bolt / nut joint, at 60% yield with anti-seize on threads.
Assumed fastener yield at 50ksi thus 30ksi when tight. Tensile area is 352.5mm^2
Oiled value came out to 276ft-lb (using 1" bolt)
NASA spec for 316 with dry lube is 155ft-lb, but I believe they use the K value for moly in that
I'm still searching for my reference charts, so any help would be appreciated!
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
RE: Torque for M24 SS 316 HCS w/ anti-seize?
FAQ725-536
Friction coefficient for austenitic stainless steels (according to VDI 2230):
0.08 to 0.16 when lubricated with "solid lubricants or waxes; pastes"
0.14 to 0.24 when lubricated with "wax dispersions, pastes"
Cory
Cory,
Are those friction coefficients or nut factors?  I don't have my VDI copy by me so I can't look it up.  If those are not factors they seem pretty low for SS on SS, even if it is lubed.  Given the diameter I am guessing that both components wil have cut threads,which can tend to bump the nut factor unless done well.
I don't have data in this size range though, so I can't help much.
Dick
Dick,
Those are friction coefficients, not nut factors.
I think those are accurate for rolled threads and MoS2-based lubricants.
Cory
Torque specs are not an exact science. If it's so critical, why not do some stretch checking.
One of the anti-seize mfrs had fairly comprehensive torqe results for some fasteners.  I could not find the link
Glad to see I wasn't the only one who couldn't find all the ref material.
Took a swag based on a few calculations and used 220ftlb for the instruction sheet. Not critical enough to warrant stretch measurements but should be adequate for the application.
Thanks!
