Safety Specs for Metal Grinding.
Am looking for some kind of industry or military spec that defines the safety requirements for a metal grinding operation in a mixed (non-industrial) space or environment. Like, removal of flamables is obvious, but how far away must those flamables be when using a 4" grinding disk or wheel at 3500 rpm or less, etc. i.e., some specific physical design paramentrs please, not generalities.
RAYBAND
Rock Island Arsenal
AMSTA-RIA-SEM
RE: Safety Specs for Metal Grinding.
Our local regs state only that "--- any equipment that produces a fire, flame, or spark at a temperature higher than 228 degrees F ---", then continues with items that are either general and obvious or applicable to temporary welding/cutting operations. There is nothing more that would give specific guidance to grinding operations.
If anyone, military or civilian, has knowledge of a spec or reg that addresses the fire safety issue for grinding operations, please advise.
RAYBAND
Rock Island Arsenal
AMSTA-RIA-SEM
Perhaps you can try the other Human Engineering specs? Search human engineering here:
http://assist.daps.dla.mil/quicksearch/
Good Luck!
Try posting question here:
http://www.eng-tips.com/threadminder.cfm?pid=190
