Copy Rotate in Sketch Mode in SW 2006
It appears that SW 2006 does not have the same copy rotate command in sketch mode as SW2005. Does anyone know a simple way to do a copy rotate in 2006?
RE: Copy Rotate in Sketch Mode in SW 2006
In the toolbar customise feature is there no specific icon to be moved into the toolbar?
Check the "What's new" section. The PDF I have, shows the functions are available.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Thank you - I see circular pattern does what I want.
Move/copy/rotate is not available in SW2006 from what I see, but Circular pattern does fine.
Thanks for your help
Move, copy, rotate, and scale all functioned as the same tool and had the same interface in 05 and there was an options box to copy. The 06 interface has move, copy, rotate, and scale standing alone. I guess this was to give each tool more powere. These functions now almost act the same way the move, copy, rotate pattern features do. It drove me nut when I first changed to 06 but I now see the light. The sketch tools are more powerful than they were before.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
