BlueBeam PDF problem
I'm trying to install SW 2005 at home on an XP Professional system.  When I get to the 2nd disc the install stops because it says it's missing a BBPDFMon.dll (or something like that) file.  I check the location and find a 0 byte file.  I can't go back to Solidworks to ask because my maintenance contract ran out.  Has anyone experienced this problem - is there a work around?
RE: BlueBeam PDF problem
Have not experienced that problem.
Workaround may be to copy the missing dll from your works machine.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
you should be able to ask you VAR on an install issue only.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
