Suppressing a component in another configuration
This is simple - simple, simple.  I'm just looking for an alternate solution.  I have an assembly that contains many parts, and in one configuration, some parts are suppressed, in another they are there.  But every time, I go to the alternate configuration, the parts are either suppressed, or not, depending on what I did last.  (I assume I'm getting confused somehow, but can't 'for the life of me' figure what's going on.)
RE: Suppressing a component in another configuration
Are you using a DT or doing the configs manually?
A DT is the better method.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Yup.  You're right.  I wasn't using a design table.  Old habits die hard.
DT much more stable.  I've all but forgotten how to do otherwise.
You don't need a DT, but you should check the properties of the part and make sure you have "used named configuration" set on.
A DT just gives you a better understanding of what it is you are setting up per config, otherwise you have to actually use your brain to figure out what is what smile... I agree I would rather use a DT.
Regards.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
