Mimick the Physical Properties of Avaiation Fuel
Hi all,
I am after a liquid, preferably water-based that mimics the physical properties of aviation fuel. I do not want anything flammable or explosive, just something that will simulate its physical properties particularly when under pressure.
I am sure there must be some additive that you can add to water that will alter its properties to that of aviation fuel?
Has anyone got any ideas?
Many thanks is advance if you are able to suggest something. I will post in the aerospace area also in case someone there has any chemical background.
With best regards,
J
RE: Mimick the Physical Properties of Avaiation Fuel
jdarcy,
1. Identical posts in different forums are frowned on.
2. You get a better response if you give more information in your question.
3. Read the FAQs. eg, FAQ731-376
