Mimic Physical Properties of Avaiation Fuel
Hi all,
I am after a liquid, preferably water-based that mimics the physical properties of aviation fuel. I do not want anything flammable or explosive, just something that will simulate its physical properties particularly when under pressure.
I am sure there must be some additive that you can add to water that will alter its properties to that of aviation fuel?
Has anyone got any ideas?
Many thanks is advance if you are able to suggest something. I will post in the chemical area also in case any chemists are familiar with this kind of application.
With best regards,
J
With best regards,
J
RE: Mimic Physical Properties of Avaiation Fuel
Once upon a time we used Rustlick B[?] for cyclic/function/hydrotesting in the shop for some petrochem process equipment.
