Materials for Boiler External Piping
Hi All,
Just wanted to get reactions to the following proposal.
It has been proposed to install a new piping system on the Plant in Stainless Steel. The system is HP Steam at circa 126 Bar and 574 Deg C. The "Engineer" has proposed using Stainless Steel for the Pipe with CrMo for the valves.
Any Thoughts??
Any Thoughts??
RE: Materials for Boiler External Piping
The Grade 91 material would be well suited provided very strict processing and handling controls are specified and verified by the owner or owner's engineer.
Going with stainless also requires some added level of process control and having dissimilar metal weld joints at elevated temperature exposure will result in long term problems. There is just no way around the elimination of reduce creep rupture life at dissimilar weld connections, as you would have with using Cr-Mo-V or Cr-Mo valves in a stainless steel steam line.
