Index exceeds matrix dimensions.
Hi!
I need a help, I am a beginner in matlab programming and I am trying to write a function to compute associative legendre funtions by recursive relations. I am getting this error message
??? Index exceeds matrix dimensions.
Error in ==> D:\Matlab\Pmbar_nm.m
On line 28  ==>     Pbar(m) = u*sqrt((2*m+1)/(2*m))*Pbar(m-1,m-1);
I have typed the following code
function Pmbar_nm = Leg(phi,n_max,t)
%LEG copmutes the normalized associated legendre functions Pnm(t)by recurrence relation
if (nargin == 0)
   phi = -6;
   n_max = 18;
   lambda = 39;
   h = 0;
end;
%Initialize n_max
n_max = 180;
if n_max > 180, disp('Degree too large for the function, Upper summation bound too large!'), return, end;
GM = 3986004.418e8;     % m^3/s^2
a_e = 6378136.46;        % m
finv = 298.257223563;   % flatenning
% We input geodetic coordinates phi,lambda in degrees
% We have to transform the geodetic coordinates to geocentric coordinates in radians
[X,Y,Z] = frgeod(a_e,finv,phi,lambda,h);
[lambda,phi_geoc,r] = cart2sph(X,Y,Z); % lambda and phi_geoc are now in radians
t = sin(phi_geoc); % phi_geoc is geocentric latitude
% Pbar computes the normalized associated legendre function on the diagonal
Pbar =zeros(n_max+3,1);
for m = 2:n_max
     u= cos (phi_geoc)
end
% Computing the normalisation coefficients a_nm and b_nm
a_nm = zeros((n_max+3)*(n_max+4)/2,1);
b_nm = a_nm;
for m = 1:n_max+1
    for n = m+1:n_max
        s = loc(n+1)+m;
        a_nm(s) = sqrt(((2*n+1)*(2*n-1))/((n-m)*(n+m)));
        b_nm(s) = sqrt(((2*n+1)*(n+m-1)*(n-m-1))/((2*n-3)*(n+m)*(n-m)));
    end
 end
q = a_e/r;
Pmbar(n-1,m) = zeros(n_max+4,1);
Pmbar(t)= Pmbar(n-1,m);
for n = 2:n_max
    for m = n_max:-1:2
        Pmbar(n-1,m) = Pbar(t)/u^m *10^(-280);
     end
      Pmbar(t)= a_nm*q*t*Pmbar(n-1,m)-b_nm*q^2*Pmbar(n-2,m);
  end
Pmbar(t)
I don't know what to do, please help me! thank you in advance.
dorodeus
RE: Index exceeds matrix dimensions.
Pbar is defined as a 1D vector.
In line 28 you reference it as a 2D matrix
... *Pbar(m-1,m-1);
M
Dr Michael F Platten
Hi Dr Michael,
Thank you very much for your quick respose to my question. let me try to correct my mistake. Thanks,
dorodeus
