5356 Aluminum filler alloy
I want to weld (using MIG process) an aluminum part, base alloy 6082 T6 using a 5356 filler alloy. The Production date of the filler alloy is: 11-02-93. I want to now if it still suitable for use, now days. By these meaning: If I used it, will I have full mechanical properties of the weld, as I would get with a more recent product (filler alloy)?
Over these years the filler wire has bean kept in a closet with no particular precaution concerning to room temperature or air humidity.
Thanks in advance
Regards.
Thanks in advance
Regards.
RE: 5356 Aluminum filler alloy
Recognize that your heat affected zone will not be T6 condition once you finish the weld.
