R507 system static pressure
What is the typical “standby pressure” AKA “static pressure” range for a R507 refrigeration system at 70 degF? Note: I am not using this information for charging the system. The information is need for a rough transient analysis during startup.
RE: R507 system static pressure
Depends upon your ambient temperature.
Best regards
pennpoint
Then I repeat my reply: It depends upon your ambient temperature. There are look up tables for psi @ 70 F.
Best regards
pennpoint
Look it up.
yours
respectfully.
