Accessing Custom Properties from VB
I think I have an easy one here, but we will see. I know how to get custom properties from my model when my ActiveDoc is the model: SwModel.CustomInfo2(). How do I get to the custom properties if my drawing is my ActiveDoc?
I am working in the drawing and trying to update the title block, but I am having troubles getting the info to put in the title block.
Thanks!
Joe
Here is the codes I am working with:
Public Sub SetNoteText1()
    Dim DrwDoc As SldWorks.ModelDoc2
    Dim View As SldWorks.View
    Dim Note As SldWorks.Note
    Dim NoteText As String
    Dim BoolStatus As Boolean
    Dim NoteHgt As Double
    Dim NoteAHgt As Double
    NoteAHgt = 0#
    Set DrwDoc = swApp.ActiveDoc
    Set View = DrwDoc.GetFirstView()
    Do While Not View Is Nothing
        Set Note = View.GetFirstNote()
        Do While Not Note Is Nothing
            NoteHgt = Note.GetHeight()
            NoteText = Note.GetText()
            Select Case NoteText
                Case "<COMPANY NAME>"
                    BoolStatus = Note.SetText("XYZ Co." & vbCrLf & vbCrLf & "COMPOSITE BEAM")
                Case "<DRW>"
                    BoolStatus = Note.SetText("AUTO")
                Case "<Order Number>"
                    BoolStatus = Note.SetText(Word)
                Case "WEIGHT:"
                    BoolStatus = Note.SetText("WEIGHT:  X LB")
                Case "A"
                    NoteAHgt = NoteHgt
                    BoolStatus = Note.SetText("A   " & "   NB  001")
                Case Else
            End Select
            Set Note = Note.GetNext()
        Loop
        Set View = View.GetNextView
    Loop
End Sub
RE: Accessing Custom Properties from VB
The easiest way to update title block based on part custom properties is to make your drawing template with notes linked to model custom properties.  But that's not what you're asking.
Now, if you want to get part (or assembly) custom properties while a drawing is the active document, all you have to do is get a pointer to the referenced document.    Declare another ModelDoc2 object variable.  I'll call it swTargetDoc.  After your line
put
If Not View.IsModelLoaded Then
   View.LoadModel
End If
Set swTargetDoc = View.ReferencedDocument
Now you can access swTargetDoc's custom properties just like you would if it was the active doc.
