Use of EVM for T&M Contracts
I am working with a group that is developing processes and procedures with use of EVM to manage projects within our organization.
The question that is causing concern is - how does one measure performance on a T&M job, since there is no "budget" to work off of?
Any help??
RE: Use of EVM for T&M Contracts
Come up with the cost equivalent if the work was done out of house.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
If you are doing T&M work the value is the extended cost of the T&M times the applicable rates and costs. i.e. The value of the T&M is the defacto budget
did you specify a "not to excced" cost?
if so, use this as the end point and run the EVM on it.
watch each trend line - work completed vs dolars expended.
