NX-3 Can I assign weight to a parasolid?
CAN I ASSIGN A  Weight TO A parasolid for a c.g. study. It is a clamp body. I know the Weight. But not shore how to assign it to the clamp body. Weight not density
RE: NX-3 Can I assign weight to a parasolid?
You can measure the volume and calculate the density from there.
Remember D=M/V  Density=Mass/Volume
Once you get the density, assign that to the Parasolid for your c.g. studies.
I hope that this helps!
Chris Cooper
Senior CAD Specialist
Cleveland Golf / Never Compromise
www.clevelandgolf.com
www.nevercompromise.com
I thought that since V16 or V18, you can assign a weight to the solid body directly.
Ben Loosli
Sr IS Technologist
L-3 Communications
