Making A Soft Plastic Tray
Hello All,
I am currently interested in trying to find a way that I can make a plastic tray at home. I'm sure everyone's seen one, they come in board game boxes and generally they hold the cards, pieces, dice, etc. I do not need mass production only like 1-2 (5 on the high side). I've read a lot of post where they're talking about doing solid plastic molding at home, which I guess is an option but it seems like a waste of materials and add's unneeded weight. It's don't think making the mold would be the problem (as I'm sure I could use clay, plaster, wood, stone, algenate, whatever to make a positive/negative), but I'm not sure where to get the plastic to do this type of thing.
Any ideas would be appreciated.
Vincent
Vincent
RE: Making A Soft Plastic Tray
Make a male mould from wood.
Set the oven to the temperature recommended by the sheet supplier. From memory, about 110 to 120 Deg C should do.
Heat the sheet in an oven until it is soft.
Drape the sheet over the mould and press it down by hand. Use a leather riggers glove to protect from heat.
