Obsoloete (?) Fischer Porter flow sensor
Hi Everyone,
I was asked at work to find out about a Fischer Porter device, which I was told was a liquid flow measurement device. My initial Google and ABB-website searches have yielded nothing helpful, so I was wondering whether anyone could point me in the direction of some documentation about the device:
Fischer Porter
s/n: 8802B2017/2/B1
Model: 50PZ1211C1X2
Supply: 120 V, 60 Hz, 50 VA
1-31' sec input
4-20mA dc output
range ft/sec (4 digit thumbwheel switch - used to specify some sort of setpoint?)
Bottom of unit has four threaded (female) openings for conduit. Printed on the bottom left of the front face (protective cover removed) is a label, "MagX".
Any guidance would be appreciated. Thanks in advance.
Richard Byrne.
Note: this thread was previously posted in the electrical/electronics engineering forum. I have since removed the original thread to avoid double-posting.
Fischer Porter
s/n: 8802B2017/2/B1
Model: 50PZ1211C1X2
1-31' sec input
4-20mA dc output
Richard Byrne.
RE: Obsoloete (?) Fischer Porter flow sensor
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
If it is old/obsolete, you probably won't find it on the web. Have you tried contacting ABB directly? Most companies have a library with old paper specs and manuals that they can copy for you (sometimes even for free).
Albert Einstein
