R Factor and Moment Frame Detailing
I haven't designed many moment frames, but I am working on a rather simple one that is part of a "canopy". The structure is only 15 feet tall and is very light. Snow loading generates the highest moments in the frame, not seismic. It is in SDC=D.
I would like to simply "lock up" the joints by welding/bolting with standard "old-fashioned" details and beam over column joints. My question is: can I avoid the detailing requirements of the AISC 341 in any way? I seem to remember reading somewhere that if you use a Response Mod. Factor = 1.0, some of the requirements may go away.
RE: R Factor and Moment Frame Detailing
Do you have a reference for that exception?
