Airbrator/Fluidizer Information
I am trying to find out some information on how to set up the pneumatic system to an Airbrator or Fluidizer. I know there is different systems that use solenoids to pulse the flow but I am unable to find out what kind of compressor or control system is required for this. Anyone have any ideas?
RE: Airbrator/Fluidizer Information
The bin activators have a control panel that turns on an electric rotary vibrator and times the air pulses to the activator.
The air cannons are internally timed with an overriding on/off switch.
The electric vibrators are control with an on/off switch. The amplitude of the vibrator is controlled by adjusting the eccentric.
The KISS PRINCIPLE should be followed for vibrator controls. Even though we could control a lot of vibrators from the control rooms there are quite a few we require the operator to start/stop the vibrator in the field.
http://www.vibco.com/index.htm
http://www.martin-eng.com/products.php?category=9
ht
