2006 SP 4.0 PDF
2006 SP 4.0 PDF
Since installing SP 4.0 from SP3.0, I cannot print a PDF created from a SW drawing. It doesn't matter if I print and pick "Adobe PDF" as the printer, or if I File > "Save As" PDF.
We have Adobe Acrobat 6 Professional and the printer is an HP LaserJet 5100.
I can open up the PDF, but if I try to print it, the printer gives an "out of memory" error. I can print PDF's from SP3.0, and even large file-size PDF's. I even tried sending it to other printers and also sent it to other people so they could try and print it, but still no-go. Is anyone else having this problem with SP4.0, or is something hosed on my system?
Flores
SW06 SP4.0
Flores
SW06 SP4.0
RE: 2006 SP 4.0 PDF
Have you tried changing the "Saved as" version option when printing to "Adobe PDF" printer?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
RE: 2006 SP 4.0 PDF
RE: 2006 SP 4.0 PDF
I went from SP3.0 to SP4.0, so Solidwork's switch from Bluebeam didn't affect me. This also explains why the PDF macro "SaveAsPDFWhatToPlot" isn't working anymore.
Flores
SW06 SP4.0
RE: 2006 SP 4.0 PDF
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
RE: 2006 SP 4.0 PDF
Flores
SW06 SP4.0
RE: 2006 SP 4.0 PDF
When saved each sheet should be saved with the correct sheet size & layout setting.
