Outdoor stair drainane
I am building a metal pan outdoor stair.  It is not a open riser stair.  I am concerned about the water accumulation.  Should I drill holes thru the metal pan so that water can go thru?
Is there other ways to solve the drainage problem?
Thanks a lot!
RE: Outdoor stair drainane
Can't you have a small slope in the treads to drain the water off?
Hi, Bagman2524,
Thank you so much for the response.
Yes, I am thinking to slope the treads and leave a small gap between the tread and stringer for drainage.
I am just not sure how difficult it is to set the slope and am wondering if someone has other ideas.
