Batch Plotting UG Files from Visual Basics
I'm actualy a Visual Basic programmer of sorts and have a lot of experience with Pro/Wildfire. What I want to know is 1) What is Grips Programming? and 2)Can anyone tell me if the UG object library is available to Visual Basics/
Thanx in advance,
Allan
Thanx in advance,
Allan
RE: Batch Plotting UG Files from Visual Basics
The distributed UG Libraries are in C or C++.
Ben Loosli
Sr IS Technologist
L-3 Communications
The newer versions (NX3 or higher) have .net as the macro language. I have not personally used this feature yet (I'm still on NX2) so I can't comment on if batch printing is possible with it. If not, it may be in future releases as they are phasing in the .net support.
On the older versions of UG, C or C++ is your best bet (as Ben mentioned), but you will need additional licenses for UG to use it (the development and execute licenses are an additional cost on top of the base UG modeling license). Maybe someone has developed C++ wrappers to allow VB to interface with UG, but if so I'd bet the wrappers don't come free either.
