Xrefs in 2006
Xrefs in 2006
I've just started using ACAD 2006 and when i attach an xref the path (as well as the drawing object I'm attaching) shows on the drawing in a string of text. I've never had this before when inserting xrefs and can't see a way to get rid of the text string.
Would be grateful for any help or suggestions.
RE: Xrefs in 2006
RE: Xrefs in 2006
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Xrefs in 2006
RE: Xrefs in 2006
I insert the xref (by brousing to find the drg I want to insert) and then I click to insert it into the current drg. The xref'd drg appears and also the text string of the path also appears.
RE: Xrefs in 2006
RE: Xrefs in 2006
RE: Xrefs in 2006
