EXCEL SPREADSHEET
EXCEL SPREADSHEET
EXCEL SPREADSHEET
Gentlemen,
How do I make excel check a column (or columns) to see if any 2 cells have the same value or expression?  Thanks.
RE: EXCEL SPREADSHEET
one way to do it - in the next column over, use the countif() function to count the number of cells with a given value.  Example:
column C has your values in it, from cell C3 to cell C21.  Cell D3 holds the function "=COUNTIF($C$3:$C$21,C3)"
Cell D4 holds "=COUNTIF($C$3:$C$21,C4)"
and so on.  If there are no matches, column D will hold only 1s.  If there are matches, there will be numbers greater than one in column D.  Use the max() function to look at the whole column for the max number of matches.
Try using the MATCH function.  An explanation of the passed variable is included in the description of the function.
Hope this helps!!!
Trashcanman,
I found the answer to your problem at http://j-walk.com/ss/excel/usertips/tip061.htm .
An array formula (entered with ctr-shift-enter) =SUM(1/COUNTIF(A1:A100, A1:A100)) gives the number of distinct entrees in the range. If expression =COUNTA(A1:A100)-SUM(1/COUNTIF(A1:A100,A1:A100)) not equal to zero then the range contains at least two identical values.
