Cosmetic Treads In Assemby Drawing
I cant get cosmetic threads to show up in my assembly drawing. But they show up just fine in the detail drawing (same compenent).
I researched the topic here and found this comment: "Starting with SW2005, cosmetic threads have to be inserted into drawings of assemblies".
Is this true? I would hate to have to insert all of those threads manually.
Any suggestions? Thanks.
RE: Cosmetic Treads In Assemby Drawing
SA
sw06 sp4.0
Try the following
1- Open the the Assembly Drawing
2- Set the Layer to NONE
3- Select Model Item
4- In the Model Item window deselect everything but for
the Cosmetic Thread icon, you might have to select it.
5- Check to see if the Layer at the bottom is set to NONE
6- Select the Green Checkmark.
They should appear now. Hope this helps you.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
