Standard Radius sizes
I am wondering if anyone has a resource for Standard radius callouts.
That is, I would like to specify a radius diameter for inside cuts of a plate for example (lightening holes) to enable the cutter to use the same drill bit for cost effectiveness.
Does anyone know where can access this information?
RE: Standard Radius sizes
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
Also if you are looking to CNC machine these a radius bigger than the cutter is best as you then have a cutter path and it does not “slam” into the corners.
its somewhat square, and the cut is somewhat square as well... a fillet on the order of .100 on the inside of the lightening cut, give or take, looks ok from a design standpoint.
so should i specify .12 min as the dimension? (1/8 drill)
again, im after low cost, ease of manufacturabilty here.
this way if it cuts in excess of .25, itll be ok?
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
Mike Halloran
Pembroke Pines, FL, USA
Your standard radius probably should be bigger than the machinist's cutter. If they are writing a CNC program to fabricate your part, they do not want to pause the cutting tool. They want to move the tool around in an arc at a constant velocity.
If I want them to use a 1/2" cutter, I specify a radius of 0.35".
If they are machining on a manual mill, then the radius is your cutter's radius.
JHG
