Results output
Results output
Dear members,
i want to write out the results data in the following
format:
"node number, nodal corodinates(X,Y,Z), nodal displacements (X,Y,Z)"
Using the field output options, i can write out displacements, but it can
only write out the displaced nodal co-ordinates. Is there anyway i can
force ABAQUS to write out undisplaced nodal cordinates, along with nodal
displacements?
Another question, any data requested from the filed output options is printed in .DAT file. Is there a way to write out ascii files in a user defined format?
your suggestions are highly appreciated.
regards.
format:
displacements?
regards.
RE: Results output
RE: Results output
I thinks that the format *.fil, only works with ABAQUS explicit.( I'am not sure)
In abaqus Visualization ->XY report-> choose your file format, for example : *.txt
RE: Results output
You can write data to the .fil file in Standard using *NODE FILE and *EL FILE. These may need to be added to the .inp file by hand (I don't use CAE for writing input decks).
Martin
