NX1 Drafting Problem
Thanks in advance for any help.  I'm having an issue that is completely puzzling.  I've recently updated a workstation with Windows 2000 and NX1.  This system functioned great without any problems before upgrading but now I'm having issues in Drafting.  When I switch to drafting, the view resolves but all text is invisible.  As the screen refreshes, all text for the model is visible but once the refresh is complete, it disappears.  If I mouse over where text should be, I can select the block and it appears visible as I move it.  Once I try to place it again, that block disappears again.  I'm using a Oxygen VX1 video card with the latest drivers.
Thanks again for your help,
Chris
RE: NX1 Drafting Problem
Oxygen VX1 or GVX1?  GVX1 is the ONLY supported Oxygen video card.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
mack shore the coller is't the same as the background
