Lower transformation temp for C.S.
Anyone know where I can find the lower and upper transformation temperature for the typical P1 to P5 materials we use?
I'm checking a WPS in one of the essential variable is the PWHT temp for C.S. is stated as 660°C.  The equipment is a combo of P1 and P4 material and they get PWHT together.  The 660°C is fine for the P4 material PWHT temp; but I want to check if 660° is in the transformation range for the C.S.  If so, then that is not good.
Thanks.
RE: Lower transformation temp for C.S.
Yes. A good reference for lower critical transformation temperatures is ASME B31.1, see Table 129.3.2. If you don't have a copy of B31.1 handy, I will list several of the published LCT;
carbon steel (P-No1) 1340 deg F
carbon-moly (P-No3)  1350 deg F
1-1/4 Cr - 1/2 Mo (P-No 4) 1430 deg F
2-1/4 Cr - 1 Mo  (P-No 5A)  1480 deg F
Also,you only need concern yourself with exceeding the lower critical transformation temperature during a subcritical PWHT because of the potential to form austenite in the base metal heat affected zone. During subsequent cooling, the austenite could transform to untempered martensite (undesirable).
metengr,
Could you recommend a website or reference that provides good background on transformation temps?  I'm thinking of something very basic that us non-metallurgy guys could grasp.  Most of my world is made of P1 materials. I'd like to be more informed on the topic.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
SteveBraune;
Here are several decent web sites regarding steel and heat treatments
http://www.key-to-steel.com/Articles.htm
http://www.steeluniversity.org/content/html/eng/default.asp?catid=3&pageid=650269858
http://serkanakinci.tripod.com/id19.html
Actually, if you Google "heat treatment of steel" you will receive plenty of hits on the public domain. What I have done over the last several years is look specifically for lecture notes on this subject. There are a number of PowerPoint presentations by materials professors at various universities. I have compiled a rather extensive list of files on heat treatment of steel.
metengr,
Thanks for the excelent references!
metengr,
Thank you for your tips.  I followed your guide and found the table in B31.1.  I never thought to look in B31.1 (I don't work with that code) since I don't recall seeing it in B31.3.   Thanks.
Yes, my concern is if the temp is higher than the LTT then I get transformation to austenite.  Hence, the WPS submitted to me as is is acceptable.
Thanks again.
