STACK PROPERTIES DIALOG BOX
I ACCIDENTLY DISABLE MY AUTOSTACK PROPERTIES DISPLAY BOX.  I FOLLOWED THE HELP AND IT DID NOT WORK.  IT SAID HIGHLIGHT A STACKED TEXT, RIGHT CLICK AND CLICK PROPERTIES ON THE SHORTCUT MENU.  IN THE STACK PROPERTIEES DIALOG BOX, CLICK AUTO STACK.  NOW I HAVE DONE ALL OF THAT AND WHEN I CLICKED PROPERTIES ON THE SHORT CUT MENU THERE IS NO AUTO STACK DIALOG BOX TO CLICK. EVEN IN THE TEXT FORMATTING DIALOG BOX THE STACK (A/B) ITS NOT HIGHLIGHTED. THANK YOU TO ANYONE WHO CAN HELP.
  IM USING THE 06 SYSTEM
RE: STACK PROPERTIES DIALOG BOX
whatahandle,
I don't have 2006, but in 2004 You have to work with
^, or /, or #, ...
Lothar
ADT 2004
ACAD 2002
Are you highlighting the text inside of the mtext editor, then right clicking to get to the Autostack properties?
Oops, didn't mean to post that quite yet!
When you are in the mtext editor, and you have a fraction that is not stacked, you need to higlight it, right click, and select stack.  Then highlight the now stacked fraction, right click, and there should be a properties options right below where it says unstack.  This will get you into the dialog box.
THANK YOU CDH
