API: IF, THEN question
My apologies for the length of the mail, but it’s here for clarity.  I’ve written a macro and boxed myself into a corner.  When I originally figured this out, I was just learning so sorry if its not clean.
On with the question:  The first go at the macro would return the values asked for as long as the assembly components were manually set to resolved.  Therefore it would work for a part or assembly.  I wanted to get fancy and have it automatically resolve the components.  From help files, I found the nRetval line to resolve all components.  All was well until it stopped working for individual parts.
I would like to build some sort of logic statement the says if assembly than resolve all components and then continue the rest of the macro, if part then do rest of macro.
The italicized text is what was added to the second version when it stopped working on individual parts
'This macro is designed to display the X, Y, & Z values of a part
'or anassembly model at the origin of the model coordinate system.
'It will display the following values in relation to the X, Y & Z axes:
    'X, Y & Z coordinates of the center of gravity
    'Resultant vector length
    'Resultant vector angle
    'Imbalance in gram millimeters
'Preconditions: Assembly document is open.
'Postconditions: All lightweight components are resolved and values are displayed.
Option Explicit
Public Enum swComponentResolveStatus_e
    swResolveOk = 0
    swResolveAbortedByUser = 1
    swResolveNotPerformed = 2
    swResolveError = 3
End Enum
    Dim swApp As SldWorks.SldWorks
    Dim Part As SldWorks.ModelDoc2
    Dim swAssy As SldWorks.AssemblyDoc
    Dim nRetval As Long
'Define Mass property variables
    Dim mp, X, Y, Z, Mass   'mass properties call value, x, y and z values, mass value
'Define Resultant vector variables
    Dim vxy, vyz, vxz   'xy, yz, and xz vectors
'Define vector angle variables
    Dim axy, ayz, axz   'xy, yz and xz angles
'Define Imbalance value variables
    Dim ixy, iyz, ixz   'xy, yz and xz imbalance
'Define display value variables
    Dim dx, dy, dz, dmass   'x, y, z and mass
    Dim dvxy, dvyz, dvxz    'xy,yz and xz vectors
    Dim daxy, dayz, daxz    'xy, yz and xz vector angles
    Dim dixy, diyz, dixz    'xy,yz and xz imbalance
Sub main()
Put the IF,THEN in this area somewhere before 'Calculate the imbalance variables
    Set swApp = Application.SldWorks
    Set Part = swApp.ActiveDoc
    Set swAssy = Part
'Set lightweight parts to resolved
    nRetval = swAssy.ResolveAllLightWeightComponents(False)
    'Get mass properties
        mp = Part.GetMassProperties
    'Convert mass properties to mm or grams
        X = Str(mp(0)) * 1000:  Y = Str(mp(1)) * 1000:  Z = Str(mp(2)) * 1000:  Mass = Str(mp(5)) * 1000
    'Resultant vectors lengths
        vxy = Sqr(X ^ 2 + Y ^ 2):   vyz = Sqr(Y ^ 2 + Z ^ 2):   vxz = Sqr(X ^ 2 + Z ^ 2)
    'Resultant vector angles
        'XY angle
            axy = Cos(X / vxy)
            If Y < 0 Then
                axy = 360 - axy
            Else
                axy = axy
            End If
        'YZ angle
            ayz = Cos(Z / vyz)
            If Y < 0 Then
                ayz = 360 - ayz
            Else
                ayz = ayz
            End If
        'YZ angle
            axz = Cos(X / vxz)
            If Z < 0 Then
                axz = 360 - axz
            Else
                axz = axz
            End If
    'Imbalance values
        ixy = vxy * Mass:   iyz = vyz * Mass:   ixz = vxz * Mass
    'Define display values
        dx = FormatNumber(X, 4):    dy = FormatNumber(Y, 4):    dz = FormatNumber(Z, 4)
        dmass = FormatNumber(Mass, 4)
        dvxy = FormatNumber(vxy, 4):    dvyz = FormatNumber(vyz, 4):    dvxz = FormatNumber(vxz, 4)
        daxy = FormatNumber(axy, 4):    dayz = FormatNumber(ayz, 4):    daxz = FormatNumber(axz, 4)
        dixy = FormatNumber(ixy, 4):    diyz = FormatNumber(iyz, 4):    dixz = FormatNumber(ixz, 4)
    'Display mass property values and imbalance values in form
        Form.dx = dx & " mm":   Form.dy = dy & " mm":   Form.dz = dz & " mm"
        Form.dmass = dmass & " grams"
        Form.dvxy = dvxy & " mm":   Form.dvyz = dvyz & " mm":   Form.dvxz = dvxz & " mm"
        Form.daxy = daxy:   Form.dayz = dayz:   Form.daxz = daxz
        Form.dixy = dixy & " gmm":  Form.diyz = diyz & " gmm":  Form.dixz = dixz & " gmm"
        Form.Show
End Sub
Thanks in advance for any suggestions.
Christopher Zona - Senior CAD Designer
Concord, Ontario
RE: API: IF, THEN question
You're 90% there.  You only want to attempt to resolve components if the document is an assembly.  All you need to do is replace
CODE
   Set swAssy = Part
with this:
CODE
If Part.GetType = swDocASSEMBLY Then
   Set swAssy = Part
End If
I replaced the old code with your code and get an error at the "If Part" line.
Is there something that I haven't defined?
Concord, Ontario
Did you remove the line
I got rid of this line, but I'm still getting a runtime error #91 at the "If Part.GetType" line.
The error says, "Object variable or With block variable not set."
Does it make a difference that I am SW2005 SP5?
Concord, Ontario
My apologies for my previous post.  I didn't specify whether the line should stay or not.  That line needs to stay in.  The reason is this.  All SW files are of the ModelDoc2 type.  However, swAssemblyDoc, swPartDoc, and swDrawingDoc are specific sub-types.  First you have to get an object for the overall ModelDoc2.  That is the line
Then, if the specific type of document is an assembly you want to perform the assembly-only function of ResolveAllLightweightComponents.  That is the "If" block I posted previously.
I know that "Part" is the default variable that SW uses for the active ModelDoc2 object when you record a macro.  I usually try to avoid that, because if the active document is an assembly or a drawing "Part" is not really an accurate description.  I usually use "swDoc" for the ModelDoc2 object and then swPart, swDrawing, and swAssy for the specific PartDoc, DrawingDoc, and AssemblyDoc objects, respectively.
