Looking for heatexchanger w/ connecting pipes
OK, not the most accurate or descriptive subject line ever, so here are the details:
We're using a Platecoil HXer manufactured by Tranter PHE in TX, and I want to know if there are any other companies anywhere that make something similar.
The HXer is basically a single serpentine tube with the space between the tube walls filled by a plate. or think of a serpentine tube with a plate welded to either side. (the real thing is actually just formed from 2 plates with channels bent/molded into them. the 2 plates are then welded together, with the channels forming the tubes)
to illustrate, it looks something like this ASCII art below - looking from the side
___________
| _________|___ -->
|(________ |
| ________)|
|(_________|___ <--
|__________|
the theory is that this is more efficient than just having the tube, since it increases the surface area for heat exchange, but cheaper than having lots of fins. The plate is basically one big fin.
platecoil is the proprietary name assigned by Tranter - haven't been able to find any other examples. I suppose it's just a "primary surface HXer" but haven't seen anything that really compares.
So here's the actual question: Does anyone know of a company, anywhere in the world, that manufactures a "Platecoil-equivalent" heat exchanger?
___________
| _________|___ -->
|(________ |
| ________)|
|(_________|___ <--
|__________|
cheers,
rad
"According to my calculations the problem doesn't exist."
RE: Looking for heatexchanger w/ connecting pipes
643 Ridge Pike
Lafayette Hill, PA (Pennsylvania) 19444-2041
Phone: (610) 828-8940
... If your soup is not terribly corrosive ...
You'd be stunned at how cheap finned tube is when you buy as little as a couple hundred feet.
Mike Halloran
Pembroke Pines, FL, USA
I don't like dimple plate because there is no control of the flow path of the fluid between the plates. It will take the path of least resistance, possibly by-passing large areas of the plate, where as the Tranter plate (there are several different styles) controls the flow to all areas of the plate.
rmw
Try this link
http://www.heatexchangersonline.com/doublewall.htm
At the same time, the overall heat transfer could be much less for the same surface area.
If anything, only the process conditions may warrant and justify the use of such design, rather than efficiency considerations. I am not sure, though.
@mike: sounds like exactly what I'm looking for (from the example I found online). I'll give them a call today. thanks :)
@rmw: Dimple plate sounds interesting, but you're right, it doesn't look like there is a controlled (or controllable) path defined. I want to maximize dwell time, so I don't think this would work. I'll look at it some more, though.
@thermcool: this isn't really so much about cheaper, as it is about exploring alternate sources. I like the product, I just have issues with the sales staff. If it turns out that my current supplier is the best one, I'll stick with them.
@panduru: the platecoil has (almost exactly) the same pressure-characteristics as a bare tube exchanger - after all, it's basically a bare tube exchanger with the spaces between the tubes filled in by a large fin.
Thanks for all your help. If you think of anything else, please let me know. :)
cheers,
rad
One more to add to the "platecoil" list: Mueller
h
Speco
cheers,
rad
They used to be in Brooklyn, NY. Maybe the move killed them. I've been through it myself more than once.
Mike Halloran
I believe that Dean went out of business several (maybe 8-10?) years ago. Another platecoil manufacturer was DEC. They are also out of business.
Speco (www.stoneprocess.com)
cheers,
rad
Sorry. Jumped the gun and didn't read your post thru. How about these...
http
http://www.lytron.com/standard/cold_plates.asp
http://www.irishassociates.com/heat.htm (See "Techmark Platecoil")
http://www.heseco.com/platecoil.htm
http://w
Hope this makes up for my bad...
rjw57
