Projecting a Curve
Projecting a Curve
I am trying to project a sketch onto a surface but it ends up being a cosmetic feature and cannot be used in sweeps.
I tried to do a Datum curve (through legacy) onto a surface, but after selecting a surface to project to, Pro won't accept the surface. The command just hangs!!
Pro/E WildFire 2.0 Date Code M160
Todd
Todd
RE: Projecting a Curve
If you have a curve and a surface, Select the curve then use Edit - Project; the direction can be specified
This can then be used as a trajectory in a sweep
What's the problem?
The project command using the legacy commands "hung" while selecting surfaces.
You solved my problem. Thanks!!
Todd Becker
Reading, PA
What did you think of SolidWorks, and is it a job change that has brought you back from the dark side?
