Questions to ask when looking for a pressure transducer/sensor.
I am working in a tubing industry and one of the nde tests we perform is a hydrostatic test at a percentage of the tubings burst pressure.  The tubing is filled with water and then pressurized with a compressor.  We are currently using an analouge pressure gauge with a rotating chart to plot the pressures introduced to the tubing.  These are very high pressures, as much as 15,000 PSI.  We have began looking to move to an electrical/digital recording for the pressure using a pressure transducer and a digital pen recorder.  The pressure will be measured extenal to the tubing on the compressor end of the system.  I was hoping someone would have information as to what should be looked for in this type of equipement.
Thank you for you help.
RE: Questions to ask when looking for a pressure transducer/sensor.
A Google query on Digital Pressure Transducer returns a lot of answers. You should be able to find there what suits your needs.
http://www.welding-advisers.com/
