polyval and polyfit functions on noisy data
I have two sets of data, 'x' and 'y'. They are related to each other.
x = 239.18 239.18 239.18 486.63 486.63 237.9 237.9 412.33 412.33 412.33 412.33 367.51 367.51 367.51 367.51 367.51
y = 288.74 301.76 333.2 166.87 210.52 337.92 299.54 273.76 224.1 197.59 199.37 251.24 247.53 236.45 233.29 204.35
From looking at the data it can been seen that the values are corrupted by noise - this seems to be giving me problems when trying the use the polyfit and polyval functions to plot a 'line of best fit'. The reason I think is because x = 239.18 239.18 239.18 (all the same value) relate to slightly different values of y (due to noise) y = 288.74 301.76 333.2. The line fitting functions seem to have problems resolving this when the line of best fit is to be plotted.
I would appreciate any help in resolving this issue.
Tom Myers
Tom Myers
RE: polyval and polyfit functions on noisy data
dont know how critical your applicaion is but this is
just a guess/approx .........
try fitting the linear fit first and estimate the mid points for each y clustered set this will give u linear fit (y = -0.5106 + 430.82)with R2 = 0.7799 (not good) with all clustered y values lying within 18% error bars.
then estimate with these points a ploynomial (y = -4exp-17 x^2-0.5106x + 430.82) with R2 = 1.
x y (LINEAR) fit (POLY) FIT
239.18 288.74 308.69 308.685
486.63 166.87 182.35 182.308
237.90 337.92 309.35 309.339
412.33 273.76 220.28 220.256
367.51 251.24 243.17 243.147
