Soldering leads on ultrasonic transducer.
I have an old but lightly used ultrasonic cleaning tank where the solder joint between the leads (wires) and ultrasonic transducer surface has failed. I can (and have) soldered them back on, but they stay on about 5 minutes and pop off again. I strongly suspect it takes a special solder because the transducer surface (there are two leads on each of 2 transducers on bottom side of the tank) is not metal; possibly ceramic?? In any case, a soldering iron doesn't burn it, but ordinary solder won't stick. Leco and Branson seem unwilling to help (surprise!!). Anyone know what will work?
RE: Soldering leads on ultrasonic transducer.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
TTFN
That doesn't work very well as one of the major manufactures installed a system where the connections were crimped/clamped. Within 6 weeks we lost all of the OEM transducers. If I recall correctly all failed on the wire side at the crimp in the connector.
