Reload border
Reload border
Reload border
How do I reload a title block.  I have edited our title block but cannot reload.  If I start a new drawing I get the desired changes.  On existing drawings I cannot seem to get the changes to appear I have saved the the template as a sheet format.
TAP
RE: Reload border
Sheet Format/Size
Standard sheet size. Select a standard sheet size, or click Browse and locate a custom sheet format file.
Reload. If you make changes to the Sheet Format, click to return to the default format.
Display sheet format. Display border, title block, and so on.
Custom sheet size. Specify a Width and Height.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: Reload border
On your feature tree, select the + to show the dwg, right-click. There are options to reload.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
