after relocation of drawings, can't open drawings from within models
We used to group all parts, sub-assemblies, and drawings of a given assembly into a folder, so a project folder contained a number of (somewhat) self-contained folders.  Then we cut each of a project's drawings from their existing locations and pasted them into one folder, leaving the part and assembly files where they lie.  Opening each drawing individually, we re-linked them to their respective models.  I can still open parts and assemblies from within their respective drawing files (RMB a view > open) but not vice versa.  Now we need to duplicate this project folder (Btw, any advice for doing this efficiently? We currently do it the hard way.), so if it's possible to repair the model-to-drawing links I would like to perform this task concurrently.  Is there a way?
Chris Montgomery
Mechanical Engineer
RE: after relocation of drawings, can't open drawings from within models
Not that I know of. The SW model does not keep a link to the drawing in its coding. All SW does is look for a drawing file of the same name, in the same folder.
BTW, if you had used SW Explorer to copy the drawings to another folder, the linnks to the models should have been maintained in the drawings. The original drawings could then have been deleted.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
