Solidworks Routing
Solidworks Routing
Solidworks Routing
So I gave Solidworks routing a try and I seem to be running into a problem.
When I create a new assembly, do I need to create a routing assembly or can I just create a normal assembly?
So then I dragged the SW example connectors into my assembly.  At this point a window should open up and ask what I would like to call the routing assembly and what template I would like to use.  (I have these options turned off in the options menu, so it should prompt me).
Anyway so now that the "Start Route" windows doesn't open I then try to right click on "CRoute1" point on the connector.  I have it selected and then right click, but "Start Route" is not even listed.
Now I'm lost as the only way to create a Route is to import the data.
RE: Solidworks Routing
Quote (christianroth):
My guess, a routing assy.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
A routing assembly should be created when you start the route.  If the route already exists, you may have to use edit route instead.
Are you sure you have Routing turned on as a SW Addin?  You might also check out the Yahoo group for piping, http://groups.yahoo.com/group/solidworks_piping/ , or the SW Corp online forum.
