importing DWG/DXF as sketches
I have close to 10,000 legacy AutoCAD file that we are slowly converting to UG NX3 solids. Most are very simple, but some have complex shapes that are swept aroung a guide line. I want to import the complex shapes into a sketch.
FYI: NX3, AutoCAD 2005, Win XP Pro, NEW DELL Laptop. I went to the Training Class at UGS, But didnt learn this.
RE: importing DWG/DXF as sketches
Import the geometry into an NX file, then add it to a sketch.  I do not have NX available at the moment (at home), but it is pretty straightforward.  While in a sketch, there is an option to add geometry.  You can then constrain it as needed.
Bump^
Rep001,
I don't think there is a way to directly add the geometry, so your pretty much stuck with what EWH suggests.  It's really pretty simple and straight forward, although there's a couple of thingies I'd suggest.
These legacy files have been through a translation or two, so you'll likely want to clean up the geometry prior to importing it into a sketch.  You might also want to set up a seed part, or otherwise customize a part file to use as the file to import all the dxf stuff into...
As such, here's what I'd do... I'd set the seed part up with a datm csys at absolute, the layering categories already set up, and prehaps another seed part set up on the drafting/drawing side to make things easier (such as using the sketch dimensions as the start of your detail dimensioning...).
As far as the nuts and bolts of the process goes...
Open the UG part
Import the dxf file
Add datums relative to the datm csys, but where you want the sketches to be...
Project the desired curves that you want to add to a sketch to the relative datm you just added
Clean up the curves a bit so that it all 'chains', as if you were going to change the curves color or make an extrusion out of it.
IF it chains, consider this geometry ready to import into a sketch
Create the sketch on the relative datm plane created, using one of the datm csys axis as the horizontal reference
Import the desired geometry
Add your geometric constraints
Add your dimensional constraints (preferable like it will be detailed *hint, hint*)
Finish creating your part
SS
CAD should pay for itself, shouldn't it?
