set and reset
set and reset
hi, another question
In a temprature-measuring program, we compare the measured value with 2 others, a low and a high limit.
If the temperature is lower then the "low limit" it has to set an output (for example, a led in LabVIEW)
and when the temperature is higher then the "high limit" is has to reset the output.
summary: with the 2 inputs i need to set and reset that LED
thanx if you again can help me out!
