Help with planetary gearbox design
Hi, I want to design a planetary gearbox with a ratio of 1:2. the output will be used to spin up a 25Kg flywheel. I have read that it is possible to design a planetary gearbox that increases the final rpm, but I am unsure of the geometry/design to achieve this.
This is what I believe will achieve the 1:2 ratio.
Power input will be through the sun gear, output will be through the planet gear carrier (the ring gear is fixed).
Sun gear has 50 teeth, planet gears have 25 teeth, ring gear has 100 teeth. (sun gear rpm: 3000, planet carrier rpm: 6000).
Does this sound right? The more I think about it the more confused I get. There isn’t much information on planetary gearboxes on the net, and so any information/advice will be greatly appreciated. I know this is going to be a difficult task, and I am at the beginning of the design stage, but its the best way to learn… by doing!
Suren
Suren
RE: Help with planetary gearbox design
internal ring gear addendum. Chech the mesh of 25 teeth
and the 100 tooth inner gear. Also check the
25 tooth planets mesh with the 50 tooth gear.
I do not think you can space the 3 teeth perfectly
at 120 degrees and have them all mesh.
I think all of the individual components must
be divisible by a prime number. 5 is a prime
number that would work so 5 planets would work.
look at 24, 48, 96 teeth combination with 3
equally spaced planets or 27, 54, 108 teeth
combination.
What you're after is a "Star" set where normally the cage is fixed, the sun is the input and the ring is the output, "Nr/Ns = Ratio". This will give you 2:1. I feel if you reverse the configuration, making the ring the input and the sun the output, it should yield what you're after. Direction of rotation between input/output will be reversed.
Remember that it’s best that "Nr + Ns / No. of planets" equals an integer.
Be very careful as the speeds you're suggesting will yield extremely high velocities at the planets & sun gears tips, the planet’s will be rotating at 12,000 rpm. I don't think your proposal could be manufactured economically as grinding of the component’s teeth would be necessary and grinding internal gears is very specialized and expensive.
To help keep the noise and vibration down helicals would have to be considered making the set even more expensive. Then there’s the specialized gear advice you’ll require to calculate the tooth geometry for a “speed increasing” gear set, the helical angle, the power requirements, etc, etc, etc.
Good luck!
http:/
The calculator.
http://www.wmberg.com/Tools/epgear.htm
The selected tooth combinations do not allow for 3 equally - 120 degree - spaced planets (pinions). And 5 of would be probably a problem to put there, seems to me there is not enough space for them...
Try another no. of teeth combinations and look in some books.
Thanks for your advice.
Suren
One more problem with planetaries: the rpm's of the planets. If you make planetary as mentioned above and drive it from ring gear to sun with fixed carrier, then the planets will rotate 100/25 = 4 times per every rotation of the annulus. Now if your input speed is 3000 rpm, we are talking about 12000 rpm for the planets.
I looked little bit closer at your gear teeth selection. You could instal 3 or 5 or 6 equally spaced planets using 100 teeth ring and 50 teeth sun.
There is an ANSI/AGMA 6023-A88 standard "Design Manual for Enclosed Epicyclic Gear Drives; it is really worth to study it when working with planetaries.
Good luck!
