Slow Updating Relations
I'm have approx. 200 different parts in my assembly (all VERY simple) with almost all of them suppressed except the ones I'm working on.  However, whenever I add a relation in sketch mode, it takes a couple of seconds for it to update.  This doesn't seem long, but it ends up being very time-consuming.  Does anyone know how I can speed this up?
RE: Slow Updating Relations
With 200 parts you are probably over the 300 recommended limit of Top Level mates. If so you will suffer performance & instability hits. Where possible create sub-assys, this will keep the TL mates down.
Use Tools > Assembly Statistics to examine your assy.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
I probably didn't give enough information.  I actually have several sub-assemblies within the top-level assembly.  I have 44 different sub-assemblies though.  I do have several relations between a part in the top level assembly and parts in the sub-assemblies.  Could that be a problem?
There could be any number of reasons;
Do you have any large sketch patterns, feature or component patterns, helices, sweeps, too much detail ..... in any of the parts/sub-assys.
Does any individual part or sub assy have a slower than usual response time?
A good start would be the Assembly Statistics though.
Also what are your system specs?
cheers
