How to copying (backup) of all assembly part files without IMAN?
Dear All,
I am facing one problem to copy all part level file of an assembly in one directory.  We don't have any file management system (IMAN/Team Center/others), currently using NX2.0.   If I open an assembly file, I need to copy all part level UG files at one place without changing any file names. Just like taking backup.  No UG/Manager is available.  Is there any way in UG that I can copy all part level files of assembly files in one directory? May be some guys suggest why can't I use Clone assembly. In this facility I have to give Name Rule. Again I need to rename whole bunch of part files. So I don't want to use Clone Assembly concept. Is there any grip programme which can runs on windows OS.
Any help really appreciated.
Thanks & Regards.
RE: How to copying (backup) of all assembly part files without IMAN?
There is a program called ugpc-zip, I think, that will take the output from a ugpc look at the assembly and zip all of the resulting files into a zip file.
Ben Loosli
Sr IS Technologist
L-3 Communications
