Linking 2 or more sketched paramtrically
I'm currently working on a project to edit parametric models via excel spread sheet. I've created a model using multiple sketches and would like to edit the position of one sketch relative to a fixed sketch at absolute. (0,0,0). The sketch that is not fixed must be able to be edited in multiple directions and angles. The two sketches will then be joined via a through curve mesh using a singe face from each sketch solid.
Does that make sense??
RE: Linking 2 or more sketched paramtrically
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
