viewing sheetmetal flat help needed !!!
Hi ,
I made a part in sheetmetal and i want to save it as a flat
and also view it as a flat.
Solid Edge version V16
please advise me how to!!!!
greetings,
Anthony
greetings,
Anthony
RE: viewing sheetmetal flat help needed !!!
you may save it as flat but why? The .psm will hold both
the flattened part as well as the designed part.
Normally one will save the flattend part only as .dxf
it can however be save as flat as a seperate .part.
(just go to File -> Save as Flat)
How to flatten:
- in the upermost toolbar --> Model
--> Flat Pattern
--> select any face to be oriented upward
--> select an edge to be parallel to the x-axis
and the Origin (tine red circle will show at
the end of the line)
--> Finish
--> Cancel
Now you can save the whole thing as usual. To either
- Model --> Flatt Pattern or Designed
or
to see the flattened part
click on Flatten 1 --> RMB --> Go To
to see the designed part
click on the last feature above Flat Pattern --> RMB --> Go To
You should work one of the tutorial that come with SE
on that topic Help->Tutorials
dy
Thanks for the info,
i wend through the Tutorials but some of the terms are new to me , living in the Netherlands ,means i speak English, but some of the technical terms used in the tutorials are hard to understand !!!
But i am learning ,and you helped me in the correct direction .
thanks ,
Anthony
Look here:
http://forum.solid-tools.com
Alwin
if your better in German then this maybe worth to have
a look at:
http
dy
