Where is the System codes menu
Who knows where i can find the System codes menu in INtools 6,
I want to add an UOM code
Kind regards,
RE: Where is the System codes menu
It's not possible to add UOM codes into INtools using
INtools menu's.
To add UOM codes insert records into table [UNITS_OF_MEASURE].
read, update and execute the following script in the SQL
query analyser.
Script is made for MSSQLserver 2000
--###########################3
-- Next script will add 12 units to the table [UNIT_OF_MEASURE]
-- for use in the alarm trip list
-- C.Snoeij
-- 12-2005
--USAGE: Run query #1 to retrieve the PROJ_ID, fill-in
--this proj_id in the script #3
--#1:
select proj_id,proj_name from project
--#2
--backup table:
select * into unit_of_measure_bak from unit_of_measure
--#3:
INSERT INTO UNIT_OF_MEASURE VALUES (
    <Fill-in last row id number>,
    <Fill-in proj_id number>,
    <Fill-in site_id number>,
    0,
    'SQL_INSERT',
    'W',
    GETDATE(),
    '<unit here e.g. mg>',
    '<description of unit here e.g milligram',
    'ML', --(see table UNIT_OF_MEASURE_TYPE for more info)
    NULL,
    NULL,
    NULL,
    0,
    1,
    'x',
    '%XX',
    NULL);
hope this helps.
Carlo
CS Webservice-Online
http://www.cs-webservice.nl
